Joel W Bergma
I have basic soldering kit.
Hey, having the exact same issue as the guy further up with his middle light going out. Every time i would wash my car, or it would rain or be humid out, some moisture would be in there and im sure it killed the wiring inside. I'd like to try fixing it myself by taking apart the light and replacing whatever needs to be done, but I haven't found any info on how exactly to take apart the light itself. Can you please explain how you did it? I just really don't want to accidentally break these as they're discontinued now and kinda rare.Mine are the version1 I guess because they have the red reflectors and backup light on the bottom as my signature on the left. When I took mine apart, there is a little box inside that has the electronic board and it was there that I found the diode sticking up. I soldered it down and a month later - same thing. I then bought the diodes as mentioned above and replaced it with a new diode. It's been 4 years and they still work good - knock on wood. If there is some type of box in yours and because it's not working, I would be tempted to take it apart and then try and determine the problem. The box or whatever could be resealed after.
That's pretty much the mantra these days. The rate at which manf and vendors have abandoned the 05-09 bracket is astounding."...they're discontinued now and kinda rare."
The ones I have are probably different as when I took the light out of car there is a little box with screws that I removed and opened and saw the Cap had blown and was up on one side. This is what I replaced.
