3.7 Gears
Sinntax
Oregon
Looking to change out the rear gears. Currently 6spd manual with 2.73s.... 1.5 rpm @ 60 mph. from what I've seen everybody says go 3.50's or 3.73's. but I don't want to nuke my MPG either. so i'm considering 3.31's.
Any thoughts would be appreciated.
Also if you currently have a gear swap, could please post what gears you have and what RPM you have at 60 mph. would be a great help Thanks.
bullitt1011
Richmond Hill Ontario Canada
My son has a 2014 3.7 6spd manual and he'll be going to 3.55's with a 6 spd manual you will still get great fuel economy and the car will be a comletely different ride. If you want to accelerate you'll be higher in the rpm band which makes for a far superior/enjoyable ride.
GriffX
Rural Germany
You guys really need a piece of software to calculate the rpm for a different gear ratio when you have 1500 @ 2.73 ?
Dino Dino Bambino
I have a red car
Cyprus
Unless you live in an area that's completely flat, you won't see any mpg loss going to a numerically higher axle gear ratio because the factory 2.73 is beyond ridiculously tall.
The optimum axle gear ratio is a 3.27 for the 3.7 manual and 3.90 for the 3.7 automatic assuming stock diameter tires.
What for? You have me! ;)
Sinntax
Oregon
3.31 is what I was thinking of going to, "optimum"? is this opinion or there some sort of HP/MPG formula or something?
