Looking for a second set of eyes from guys who have done gears on S197s (especially 3.55 + Truetrac setups).
The car is my 2009 Mustang GT with New 3.55 Ford Performance gears new Eaton Truetrac New bearings throughout Raytech Solid pinion spacer (no crush sleeve).
From what I can tell, it looks like a good, usable pattern its just not "perfectly centered" heel-to-toe. I've heard Ford Performance gears can look like this and settle in after break-in.
Setup details:
Pinion preload: ~17–18 in-lb (new bearings and I'm running on the low side for road racing)
Backlash: right at .009 (checked in multiple spots, consistent)
Raytec solid pinion spacer
Pattern:
Slight bias toward the toe on both drive and coast
Centered vertically (not deep in root or running off face)
Good contact length across the tooth
Not sharp or edge-loaded
Main questions:
Appreciate any experienced input, I'm at the "button it up or chase it" decision point.
Setup details:
Pattern:
Main questions:
- Would you run this as-is for street + road course /track use?
- Does the slight toe bias concern you at all given the backlash is .009?
- Anyone running a similar setup (3.55 + Truetrac) seen patterns like this and how did it behave long-term (noise/wear)?
