Rayne2ravage
Not sure what happened but recently my trunk ajar notice won't go away no matter what I do. Trunk is shut with no issues. Can open and close like normal I believe. It's a 05 GT. Maybe something is old or worn out?
It does. Or did. Not sure what years apply.Does the light inside the trunk stay on when you push the little button on the inside of the lid? I'm not sure where the display gets its input for it being open but I would wager it comes from the same button.
Did you find out if the switch is working properly?I'll check it out now
Need to replace that switch.Pressing this makes the light turn off but it feels like something in there is broken or something
Or just unplug it right? If the trunk is open, the switch is closed to turn the light on.. if you unplug it then it'll never close, light never comes on and the car just assumes it's never open.... just thinking. For the moment, or even forever - why not bypassing the switch with a simple wire ? Only downside I can see.. IF the trunk is open...there is no warning light on the dash.
I imagine from slamming this shut. I notice when I turn the key. You have to physically lift the trunk. It doesn't "pop" open a half inch or inch. Maybe the springs are worn down as well?The plunger inside the boot was broken
