Basically what you need to do is find the sweet spot where they no longer spin. Sounds simple enough I know.. but it is different for everyone and no one is going to be able to tell you where you need to be with your car. They can only give you a general idea based on tire size and rear wheel horsepower. Pick a starting place with air pressure, go launch. If you don't spin, raise it 1psi. If you do spin, drop it 1psi. Just keep going until you find that "sweet spot" for your car.
I don't have any problem cutting low 1.7s at 18 psi with 285/60-15s
