Status
Not open for further replies.
psfracer
billy badass
Valencia, CA
60' 1.74
330 4.87
1/8 7.87
mph 104.36
1/4 11.24
mph 129.6
I spun out of the hole and short shifted into 2nd on this run. More seat time, maybe some new DR's and more practice should net me a 10 second ET. Slicks would probably get me pretty well into the mid 10's maybe a bit better.
Timeslip? Also list any info that I am going to need that is not in your sig already.
Took long enough, but it was sweet. Number 949. Also note changes to set up:
298ci
M/T DRs 325/50 15
4:10 gears
12 PSI
picture.php
displayimage.php
displayimage.php
I can not see the timeslips for some reason.....
12.7 @ 106 w/ 1.7 60ft & .02 reaction time
read first post http://s197forum.com/forum/showthread.php?t=5218
scramblr
New Braunfels, Texas
scramblr
Ok, I can see that. Not bad seeing how you race on an airport tarmac over there, right?
O.K., good. And yes, I'm racing on asphalt with no VHT, same as racing on the street with DRs. It will be interesting to see the 60' times I can get when I'm back in the States on a prepped track.
Born To Run
Woodstock,Ontario
New best
Well i got some personal best 1/4 mile et's & 1/8 mile on the weekend.Here's the slip,not bad for all stock internals eh!! Its hard to read so here is what it says.
Can i be on the et list now?
R/T .038
60' 1.492
330' 4.404
1/8 6.880
mph 98.55
990' 9.026
1/4 10.837
mph 124.25
psfracer
billy badass
Valencia, CA
As I explained to GT RO, if you are from Canada the times don't count.
I can read the slip fine, great 60' time. Will add you and scramblr on next update, should be this weekend.
Born To Run
Woodstock,Ontario
New best
I have had better 60' than this one,oh well.
Maybe we should start a best 60'???
I should have posted it in Meters & Kilometers Per Hour.
I have a second slip that is even harder to read,it was within 2 hours of the first slip,do you need it posted up here as well,i read somewhere that you had to submit 2 time trials?
Where do i post all the other info,engine ci,power adder,tire etc???
psfracer
billy badass
Valencia, CA
Post all of the other info here in this thread, or in your sig. And I already know you run your car at the track and have already been in the 10s, but yes, technically you need to post another slip.
dtuna42
South Jersey
My first post on this forum- might as well get on the list... I don't know why Atco didn't didn't print all data on my lane that night, sono printout of the time for 330' (4.855) or mph for 1/8 (92.26), but I have slips of 11.72, 11.74, 11.77 & 11.80 from another night at Cecil County if you want them. These are the only slips I scanned in to computer so far because it was the night I did the best et of 11.696 @ 117....
2006 Mustang GT
281cid (stock block/heads)
2.3L Whipple HO Kit (9.4 lbs boost on dyno)
5R55S automatic
3.73 gears
265/40/18 MT ET II (street drag radials)
Born To Run
Woodstock,Ontario
New best
Here is my 2nd timeslip,it reads
RT .065
60' 1.526
330' 4.425
1/8 6.903
mph 98.68
990' 9.050
1/4 10.859
mph 124.56
Engine stock internals & heads 281 CI
Tires MT ET Drags 15x10x28"
Trans 4R70W
Supercharger Kenne Bell 2.6L
Weight with me in car 3705
I think that is all??
Status
