Plug change interval
KungFuHamster
Ft Worth
So i just finished searching for an actual spark plug change interval and i havent found anything concrete.
i found several threads discussing the procedures and what not and ive seen anywhere from 2k miles to 70k mile changes.
so my car just rolled over 30, 400 miles...is it time to pull my plugs? Or is the reason that people just go ahead and pull them is to add some anti-seize to the threads? if i pull them i will just go ahead and put fresh ones in there, but i was just curious now that my car has this many miles on it.
GIG4FUN
Rock 'n' Roll Moderator
Iowa
go get your owners manual and flip through the maintanence section...
BUT the anti-seize thing is surely something to do right away...
KungFuHamster
Ft Worth
right...thats what i was attempting to allude to (and seemed to have failed)...it would appear that pulling the plugs to add some anti-seize is something that has no time frame...other than sooner is better than later.
GIG4FUN
Iowa
:thumb: I did mine BUT I did not do the wifes! she just rolled 37,000. I am getting that feeling that I better get in there more and more every day. She has the extended Ford warranty BUT I don't know if they would do this for free if it went south. If I "knew" I would just have her schedule a "plug change".
GIG4FUN
Iowa
Gig, the extended has a $100 deductable.
damn...you are hurting ME. :pissed1: (more lost sleep)
I will do it myself. I did buy the spark plug extractor tool a long time ago just to have it! :thumb:
JeremyH
3V Fuel Guru
Virginia Beach
If your 08 has the redesign heads/different plugs you dont have to worry about this issue.
white05gt
Illinois
Even if they break the plug off, I believe they charge you to remove them since plugs are considered maintanence.
Houston, TX
This is what I have been lead to believe too! I changed my plugs with 60K+ miles on my car - no issues in removing them, plenty of treads here on how to remove them.
JeremyH
3V Fuel Guru
Virginia Beach
sadly i have the coil packs that say 3L not 8L so i have the old style shit. :handjob:
Gotcha that sucks, damn mid year changes, i had to deal with that with my 01 GT, since they made 6 bolt romeos and 8 bolt windsors that year lol, also changed the tranny, i did get the tr-3650 which i was happy about.
KungFuHamster
Ft Worth
hahaha...yeah i had an 01 as well! mine actually had a T-45 with a romeo motor
Greg Hazlett
Stepping on the Pink Bus
Official Vendor
Chesapeake, VA
And after both of you used Steen Racing you had no idea what you had, LOL! For all you knew you had each others engines/trannies!
JeremyH
3V Fuel Guru
Virginia Beach
Lol small world! i had the 3650/romeo, also there was a water pump/pulley redesign that yeat too so you had to be specfic for underdrive pulleys.
Franchi
Senior JR Member....
In a house, with a mouse
My car's at 29k and I plan on swapping it out with Brisk plugs shortly. More of a preventative thing plus when I get my cams and delete plates + dyno tune in beginning of May, I want the new plugs in for that.
Riptide
Will work for Mustang.
Montucky
Same here. You would think there would be some sort of policy the dealers would all follow and it would be the same everywhere. But it isn't.
