From the shop manual rod side clearance is 0.006 - 0.020 (my engine is 0.020)
Crank end play spec is 0.003 - 0.0148 (my engine is also 0.005)
So technically, your engine is 0.002 out of spec on the rod side clearance and within spec for the crank.
Good stuff! I'm happy you didn't part it out and are moving on with it.
What shop manual do you have? Mine is the Ford (Helm Inc.) Shop Manual and it states everything in metric measurements. Also, what I stated prior, somewhat conflicts with what my manual states but I still stand behind the belief that just because something is "within spec" does not mean that it should not be in a different area of the allowable tolerance. That being said, here's what I got:
1mm = .03937"
Thrust Clearance: .130mm-.301mm = .005" - .011"
Con-Rod End Clearance: .150mm-.450mm = .006"-.018"
Ron, If this offers any reassurance, then my objective has been met.
I'm pretty sure I'm looking at the right specs
Its not done yet? I can't wait to see what you find when you take the Larry H block apart.
I can as I am still running mine....I really do not want to know anything till it lets go and I build another one....I'm still skeptical on the whole deal with Larry_H but (knock on wood) it is still holding up fine even with 21 psi street tune....
The last snag we hit late last night was the motor would not turn at all. We ended up removing the cams and it didn't solve the problem. Had we not been completely exhausted we might have figured out before removing the cams that the motor's stroker crank and bolts on the caps were striking the stock windage tray. I didn't even know there was a windage tray down there. Brian said he told me he was putting it thre but i didnt remember so that caused some grief but luckily easily remedied.
