JeremyH
3V Fuel Guru
Eboost2 install
Got the Eboost2 in the mail yesterday and got started on modding the roush vent pod to fit it. I thought it was a 66mm unit but it was the smaller 60mm unit which worked out great. Got lots of pics for ya.
I followed the roush instructions for installing the ventpod and they worked well.
The roush vent pod is designed for a 52mm gauge so i had to remove the inner ring and trim down the tabs to fit the 60mm eboost2.
After i had the inner ring dremeled out, i slowly removed plastic with the dremel evenly from each tab till the eboost2 would fit snuggly.
Some test fitting with the trim ring on
