Anyone know anything about this turbo kit?
antonio1988
Redline: 8600rpm
Miami, FL
Bobby
turbo gt about to go fast
just out side of charlotte north carolina
yes that is on 3 performance turbo kit and is a great kit. yes you can up grade the turbo and maybe the bov and waste gate and have you self a reliable daily driver that makes great power. i have seen these kits and installed them and they are great. all you will need is the fuel system (fuel pumps, injectors, and tune) and you are good to go make 450-500 on stock motor.
antonio1988
Redline: 8600rpm
Miami, FL
Well then... everything is going up for sale then lol. Cams, longtubes, and a nitrous kit should be enough to just about get me this kit, thanks for the quick response!
Bobby
no problem man if you have any questions at all let me know. also have all the hot side coated high temp along with the stock exhaust manifolds and the exhaust side of the turbo. one other thing to get is a turbo blanket and fiber glass wrap. all of this will help hold in heat and make the turbo spool up faster and make more power on less boost, and will lower under hood temps.
antonio1988
Redline: 8600rpm
Miami, FL
you are my new best friend lol, thank you very much I will be in touch if I have any questions!
antonio1988
Redline: 8600rpm
Miami, FL
Question: With this turbo kit, do I have to remove my delete plates and under drive pulleys?
AJ
US Muscle, AUS Hustle....
antonio, buy mine... carlos put it on and took it off ;)
I have someone that has it claimed, but if that falls through...
AJ
no. you want the delete plates. those are very necessary with FI. and the pulleys will be fine.
I wouldn't VERY necessary, but rather recommended ;) I know a few ppl who have never taken them off as well as me
