Anyone know anything about this turbo kit?
JeremyH
3V Fuel Guru
Virginia Beach
Kind of... I already got a tial 38mm w/g and a greedy turbo timer and boost controller that are going in right away and a tial bov may be in my hands by next week. The turbo may also be upgraded by the end of the summer to the precision 67mm ball bearing
Sounds like plan! Im not running a turbo timer though.
JeremyH
3V Fuel Guru
Virginia Beach
Good luck with the kit man, I love mine hope it all works out for ya. Any questions just ask I'll be more then happy to help ya out.
Glad to hear everythings going good, im sure i will be asking oyu a few questions once i start installing mine.
JeremyH
3V Fuel Guru
Virginia Beach
Gotcha, interested to see what you come up with and if you wanted to bounce any ideas off me, just let me know. I spend quite a few hours under the car when we were laying everything out and that was just our best idea of how to get it done for the target hp levels. If you are going with single inlet/outlet opposite ends, we have a 4" core, 3" inlet/outlet upgrade available for other kits if you needed one. Dont know if you have one already. If you need specs just let me know
Yeap already got the intercooler too, thanks again though lol!
On 3 Performance
And here is the 3" in/out 4.5" thick intercooler im going to run.
wow you really have cleared out a lot of room between the engine to radiator. That will make things much easier in your case with wanting 3" from compressor to tb
Bobby
turbo gt about to go fast
just out side of charlotte north carolina
he just did away with that huge fan shroud and fan, rad., and then put in that slim line fan and did the sway bar delete kit. it looks like upr rad support. i have one that i powder coated flat black.
Boorail85
Kit minus turbo, wastegate, bov, and oil filter relocation. I wanted to delete the coldside as im doing my own but they wouldnt do that, which is fine. Still a good price for piping and hardware.
I have a precision 67mm, tial 50mm bov, and tial 38mm wg i will be using, and doing my own coldside 3" from turbo to tb.
What did the kit run you with the deleted options? If you fon't minf me asking.
JeremyH
3V Fuel Guru
Virginia Beach
antonio1988
Redline: 8600rpm
Miami, FL
Cant see the pic, so where did you find these prices? Be careful there are a lot of knockoff parts for this stuff out there.
Lol check the pic when you can, it is indeed a tial w/g. The guy is a friend of mine. He went from a single turbo setup to a twin, and since he has all the money in the world, he bought all new everything again lmfao. Which is why he basically gave this away to me
JeremyH
3V Fuel Guru
Virginia Beach
Gotcha, nice! yeah i cant see the pics at work. For the 44mm to work with this kit, you would have to weld on different flanges. As the 38 and 44 design is different.
On 3 Performance
Carefully pull the cap and look on their site for the color of the spring you have. Its under a good amount of pressure in the gate if he was running 10+psi so be sure to hold the cap and have someone else pull the top bolts.
JeremyH
3V Fuel Guru
Virginia Beach
they make and adapter for it. that is what i did. just bolts right up to the 38mm flange and has the v-band for the 44 made onto it.
Havent seen that before, thats good to know. But wouldnet be better to just cut off the 38 flanges and weld on the 44mm. Wont the 38 size still be there with the adaptors to slightly bottleneck flow?
JeremyH
3V Fuel Guru
Virginia Beach
for sure. i almost didnt get the 14.6 psi spring back on, but i guess it didnt help i was doing it my self
Vise!
AJ
US Muscle, AUS Hustle....
this is gonna get interesting!
