Need help ASAP! Extending MAF wiring?
antonio1988
Redline: 8600rpm
Miami, FL
Is is ok if I take the connector that plugs into the MAF sensor and cut and extend the wires? The wire is too short and will not make it into my MAF sensor, this is the last thing I need to get my car running
1fast05
I wanna go fast
Gulfport Ms
My wife's is extended all the way over to directly behind the passenger headlight
bigray327
League City, Texas
Just make sure you do it right, with soldered connections, shrink wrap to keep water out, etc. And keep those wires away from rotating parts... ask me how I know. :)
TexasBlownV8
Formerly TexasBlownV6
Central Texas
Many blower kits have you splice the maf wires to make them longer.
I've never had any issues extended maf wires.
As stated, just make sure you solder connections and use heat-shrink and seal the connections to keep them sealed and clean, and secured out of the way of moving parts.
Splice one wire at a time to make sure you don't cross any wires, if that helps!
95ragtop
Fayetteville, NC
Just go buy a mafia. I extended mine last year and then bought the aftercooler, so I had to buy the mafia anyways.
NastyStang113
Made in U.S.A.
Central Florida
Don't most s/c kits require an extension of the MAF wiring? Mine did.. Very easy. Take your time and solder it neatly, heat shrink it, and wrap it up with 3M electrical tape. Done! There's no fucking reason to add a MAFIA for this...
antonio1988
Redline: 8600rpm
Miami, FL
Thanks guys, when I got here to BBR Chris took everything and did it right for me, I had simply extended without soldering, I didn't check my own thread lolz
antonio1988
Redline: 8600rpm
Miami, FL
what did the car make
Well we put the smallest spring in there now (yellow) and the car should be making 4psi but it's making 13psi... 370 horse at 4300 rpm is all we've been able to get it up to with 9.5* of timing... I don't know wtf to do now
Miracle
"Shall not be infringed"
Clarksville, TN
Save yourself the headache and buy a mafia IMO
He's talking about physically making the harness plug longer. No need for a MAFia.
Since the OEM MAF reads both air intake, AND intake temps, the Kenne Bell kits require you to cut the OEM MAF plug off the harness, and separate the IAT wiring, and the MAF wiring, in order to put the IAT sensor in the manifold, and the MAF behind the passengers headlight, where the filter is housed.
kahmann
Sacramento
Why are you only able to run it to 4300 RPM? Why are you only running 9.5* of timing?
Timbostang
Boost junkie!
Cut-n-Shoot America
Cut the spring down a little and put a manual boost controller on it. If you are still on the stock maf you are probably going to max it out around 425hp. So the mafia would have been a good idea.
antonio1988
Redline: 8600rpm
Miami, FL
I have a BA5000, no need for a mafia. Everything has been resolved so thanks once again guys, check my other threads for the results.
