DynamiteBlues
Sandy Restore Team
So i installed my FRPP hot rod cams and loaded the tune, started it up and everything went perfect. put it through a few heat cycles, got on it a little bit and it felt ALive as hell 4k+. hardly gave it much throttle though. it was cruising butter smooth all day then out of no where, it started sputtering and felt like it was missing and the entire engine started sounding deeper. Now i get P0012 over and over. i cleared it and it would come right back. I removed the cam position sensors and switched sides thinking maybe they're faulty and the cam isn't retarded like they think. nope still P0012- same side. But i actually got a P0340 after doing this as well. Hopefully that will Not come back. but what i think happened is - I lost a bit of the black rubber OEM sealant into the timing cover. i'm thinking i might have gotten a VCT solenoid stuck open from the debris and and out a VCT sensor. I want to switch the sensors to see if the code switches sides but what if the debris has it still stuck open? will it than take out another sensor ? any ideas or possibilities? i really don't want to take my timing cover off.
