GB10
8s coming soon?
Lightblade, what was the fuel pump duty cycle on the 12psi tune? I'm just wondering how well your fuel pump and wiring upgrade is working.
That's without a BAP, right? Intercooler must be working well too if the iat is that close to ambient.75% at 12psi, Mike and I talked about that too, and were glad to see duty cycles there at that power level. On a side note i did mention yet that iat's were within a few degress of ambient at 12 psi also.
How far can we push the stock crank? Congrats again!
i hear 600 or so but not sure exactly
Hmm Trying to think if I could get by with just forged rods and pistons or if the forged crank is something I should do why its torn down...Want 600rwhp eventually
If youre in there already then you might as well replace everything at once.
I am Anthony Gonzalez and I approve this message
+1...almost always better to overbuild for safety.
i would wile i was in there
So...Rods and pistons would be okay ??? Thanks SD for CLEARING everything up!!!
Well you dont NEED a safety loop on a driveshaft. You also dont NEED an intercooler on a turbo. So have at it. Like I said I would do everything while I was in there in case you decide to take the car further then youre already set up. But hey thats just my preference.
I agree you dont ever need a driveshaft safety loop, but its a requirement at certain levels at most tracks, and yes you dont need an intercooler but it WILL effect performance. The fact is the stock crank is going to take what ever power you throw at it, and is no where near a weak link in the engine.
I wouldnt say any lol But I see what you guys are saying.
But in my point a view I would do it. Just cause I know how I am. Once I make it fast, then it just needs to be faster. So Id rather prep myself for that and not have to retrace my steps. Just like when I had 60lb injectors to push 400hp lol but now Im at 480 and theyre just fine
I hear ya too, nothing wrong with that mentality. But plain and simple these cast cranks have been proven to 1000hp, Just like the stock block.
Its prolonged high rpm that can cause problems with the oem crank.
Says who? SD?
how many broken cranks have you seen? (not asking in a smart ass way...just actually curious if you have seen a failure?) i have not seen or heard of a single failure other than one guy who was running a pro charger and snout got screwed up some how....
This could be because most people who build there bottom end also swap out the crank to a aftermarket crank? How many people do you know, besides 3 people here, that actually use the stock crank in a build? Maybe a half a dozen?
