smoken1986
Ok all I am trying to find out what is causing my clutch pedal to stick to the floor on 6200rpm shifts? I just pulled the trans yesterday and replaced the slave and its still doing it. There is no air in the lines (bleed it three times just to make sure) pedal feels fine and shifts fine normally.
I have seen that a couple others have had this problem but no solution was posted. Also I read a couple have had this problem on the 11's and it is the clutch.
I am running the t6060 with the spec 3+ clutch with only about 3k on it, and as stated above I just put a new oem TB and upgraded clutch line in yesterday. Let me know what you all think so I can order the parts I need. I am thinking maybe a pressure plate going bad or bad master cyl.
thanks
nick
thanks
nick
Spec! The pressure plate is too stiff.
