you dont have to install the coil covers if you dont like them. to each his own as they say.
Looks great. Do you have other mods on that car? Did you use the canned tune or custom tune? Do you have any 1/4 mile times?
I'm looking to make a SC the only mod. At least for a few years.
Around 500 to the wheels seems to be the line
Thanks, and this E-Force will get it there right "outta the box" with just the kit and tune?
ehhh highly doubt that.
OP: if you want a DD blower, look at the m90, its safe and cheaper.
If not, just get a TVS. save yourself the hassle now. or any other blower for that matter. Centris will shock your drivetrain a little less and save you in the long run...
it will get you close i plan on purchasing brenspeed's stage 1 kit that's rated at 560 crank. i dont want to push my luck with the bottom end holding up any more than that. they also have a kit thats rated at 600 crank hp just look around there are several companies that sell the E-FORCE with a custom tune that pushes more power than the kit from Edelbrock
http://www.brenspeed.com/05-08-mustang-power-adders-edelbrock-supercharger.html
this is a link to their website if you want to check it out.
The Eaton plant that make and grind these rotors are right across the street from were I work, They put the same rotors in alot of blowers, their biggest customer is GM...The biggest difference in the e-force is that it's a front intake blower which in turn takes the the air charge in the bottom and blows it up though the intercooler and back down the runners. Instead of the others that are rear intake and then blows it down though 90 degree bends.
Thanks for the link. Definitely looks like something I could tackle myself.
Certainly don't want to hijack this thread but which concept is "better" for building power?
I traded my V6 for this GT recently with the sole purpose of adding a power adder so any info is appreciated.
To the OP, if this offends you and you feel like I should start my own thread I apologize in advance and will do just that if need be.
