heres a guys t/a i know, think it's a 96
yup that's what i was talking about! Thanks beef
For those who are curious, they weigh 21lbs. each for a total of 42lbs.
The Magnaflow muffler deletes in box shipped weigh 22lbs..
Without packing and box, you are looking at about a 22lbs. weight savings. The nice thing about this is when you begin adding control arms, relocation brackets and rear girdle/axle tube braces, you are probably a little ahead of the weight game.
I just put a flowmaster hushpower axleback on mine. weighed both. stock weighed 42. flowmasters were 24.
Really....
Minus the indentions.
SSW appears to be a fluted design.
I would like to know what kind of in the car drone you get with either of these setups. 2000 rpm cruise. Will it drive you nuts on a long trip?
Thanks
I've experienced none of that 2000 rpm drone with the Hushpowers that you use to get with the old 2 chamber flowmasters.
Thanks, yours sounds good. Who did your programming?
Hey, sorry to post the foto again...I have the same dent on my drivers side,
also..this is a pic of factory pipes, correct?
Took it in, they threw it on the lift, and said they would get a new one
"when the part showed up on the computer"
I can't believe those things retail for $600.00 bucks. Did you find them for less???
Yes factory. The indentations are there on all cars. That is due to the machines used to hold them in manufacturing.)
