Introducing the JDM 302E Stroker shortblock!!!
Rpm427sc
Portsmouth VA
Will there be enough piston/valve clearance to run STAGE 3 Blower SPR cams (Part Number: 127650), with the included pistons?
JimIII@JDM
Yes it definatley will have plenty of clearance. We have used these cams before with even higher compression (flat top) pistons.
JimIII
JimIII@JDM
Just wanted to let everyone know we only have 15 more available at this special price of $3499!! Ford Racing no longer has any of the 05+ aluminum blocks in stock and this is going to make us purchase from Ford parts and service which has a price tag nearly $500 higher than Ford Racing. This is going to make us raise the price to $3899, so if your looking at one of these engines right now is the time to buy!!
JimIII@JDM
We are down to only 3 Shortblocks now guys!!!! jump on it while you still can!!!
JimIII@JDM
Well this engine can handle up to 1000 HP but you should stand to gain 40+ HP from adding the extra cubic inch. Now Im not sure where the car stands now but that is a signicant gain in anyones eyes! Plus it has the ability for you to add boost, heads and cams, or nitrous, or whatever you want to make more power and take it!
