These were only used for a couple dyno runs and are in perfect condition. They are the correct height for the 05+ Mustang. I will also include the USCAR adapters so they will work with the 05+ injector harness. I will post pictures tonight $450 shipped obo.
Per Lethal's site
Bosch 105lb High Impedence MINITIMER High Flow Injector
All new at Lethal Performance is the Bosch High Impedence 105lb Injector. These injectors will support over 1000rwhp and are what we run on the Lethal Performance 2010 GT500. These injectors have a Minitimer/Jetronix style connector so on vehicles that have a USCAR wiring style harness you'll need to run the Ford Racing adapter kit M-14464-U2J which will allow you to run this injector on your vehicle. USCAR vehicles are 03-04 Cobra/Mach-1 and any 2005-2011 Mustang.
These injectors also come in 2 sizes as far as height goes. If you have a 05-10 Mustang GT or GT500 you'll want to choose the EV14 height from the dropdown menu. If you have a 96-04 Mustang GT/Cobra/Mach-1 then you'll want to choose the EV1/EV6 height from the dropdown menu.
These injectors come as a 105lb injector from the factory and have not been modified or drilled to reach the 105lb rating.
Per Lethal's site
