will i break 600 RWHP?
circusboy
everything in my sig minus the underdrivepullies and add
PAxton NOVI 2200
air to air Intercooller
2.75" pulley (16 to 18 lbs boost)
8 rib setup
heavy duty belt tensioner
gt 500 fuel system with dual BAP's
60 LBS inject
what you think?
SteveP
Modular Specialist
Boynton Beach, FL
Running stock tranny with 603 here with no issues.
What type of cams and heads are you doing? I may be shy of it
circusboy
stock cams, but i do have manley .550" lift springs still in the stock heads.
Dave
Ahh just talk to the Honda guy I saw tonight, he said mustangs are weak, his 1.6 can put out 500 to the wheels n/a! I spit some beer in his face on accident laughing.
circusboy
I haven't dyno'd the motor N/A. I used to have a turbo on it. I would say the motor is +/-300 flywheel.
KrisR
Wyoming, MN
I kinda doubt it. I would guess somewhere in the 530-540 range on a Dynojet. Mine has 8.5:1 CR, stock heads/cams/intake/tb, Vortech T-trim with FMIC, 2.87 pulley which makes 15-16lbs at 6700, and my last dyno tune was at 524/467, and that was with E85. You shouldn't need the BAPs, BTW. I don't have them and I have plenty of fuel with E85.
TonyN
Ford Junkie
Virginia Beach, VA
Hmmm I don't know. Stock heads/cams.... I am thinking if you get up to 18 psi, you may see mid-high 500's with a good tune.
circusboy
i MIGHT HAVE TO THROW SOME LONG TUBES ON THERE. i GUESS i'LL DO WHAT i HAVE TO TO GET THE 600 MARK LOL.
JeremyH
3V Fuel Guru
Virginia Beach
With that blower and 8.7:1 compression at 16-18psi probably around 540-550rwhp.
If you want 600rwhp put the turbo back on! :)
604rwhp at 15psi, 9:1 compression.
Stock 3650 and rearend...
Germeezy3
The simplest solutions is often the best...PLUS 1 for you!
