Uhhhh..you could call it that....laid into it, went into the other lane, lost traction, off the road into someone's front yard, into and over a small ditch, car still running, drove out the driveway and got it home...no CEL but on the way home I had the check charging system alert and no power steering, pulled it into the garage and somehow I knocked the serp belt off....?.......pushed/bent the heat exchanger up, the condenser to the radiator and fucked up the black plastic insert on the lower part of the bumper....oops.
I have a small drip from the boot of the driver side rack/pinion steering so I may have damaged that, not sure.
Scared the shit out of myself, can't speak for Jeremy....thought UCA's helped with traction issues! At least the install of that went without issue.
