Another how much horse power I could expect?
waldogt07
Pelham, Alabama
The nitrous controllers usually have a Window, WOT, and lean safety switch built into them so you will be fine. Just so you know when set to activate progressively it will eat up the solenoids faster than if it just activates at a certain shot instead of ramping up to it. You can set it as low as 3000 rpm if you want to but again DO NOT SPRAY THRU SHIFTS! Make sure your window switch is set at least 200 or 300 rpm before your car shifts.
Thanks for the info!! I will make sure of that....I will let my tuner do most of the work as far as making sure that everything is safe....I just won't have it to where it ramps up to the 125 shot...I will just let it be that shot and leave it like that because that would be all I need if one of my solenoids went out....Thanks again Germeezy for your help!!
gojrracing
Ok, I got my complete nitrous kit with all the goodies and I will be installing it next Monday and going to have it Dyno tuned the following week....I just wanted to get an idea of what to expect from all the mods I already have and then adding the nitrous on top of those. I also am taking the K&N off and putting a JLT on which will I hope give me a few more ponies than what that silly straw that is on there does. I will be starting off with a 125 shot and yes I do have the boost a pump to cover the fuel system. Keep in mind that I am also an Auto as well.
My current mods are as follows: Hot Rod Cams, 3.73 gears, BBK UDPs, o/r x-pipe, Hooker Longtubes, flowmaster mufflers delete plates, 62mm BBK TB, 3.5'' Spydershaft DS, adding the JLT, and 93 Perf. Bama tune
When I had it dyno tuned for the cams it dynoed 319rwhp/310rwtq....Please let me know what your opinions are and what you think?? Advice and comments are welcomed
How much did it cost you to have your mods about hot rod cams?
waldogt07
Pelham, Alabama
Are you asking how much did it cost me for just the hot rods or how much for all of the mods that I have done including the hotrods???
I didn't really understand what you are asking??? Sorry...
