Things are changing
psfracer
billy badass
Valencia, CA
I like those pictures.
So is the 8.43 still your personal best? 1.30 60' times on the rear tires is pretty stout. If you can keep the front end down that would be 1.21, 1.23 60' times yes?
vinnybarber
cox's creek ky.
8.44 is my best.
You might be right on the 60ft.
I was guessing 1.25
It was first time I had control of computer. Lee blankenship has helped me learn on it.
It was hitting so hard we broke the
Planetary gears
vinnybarber
cox's creek ky.
Update,
Trans is back with new planetary gears.
Converter has been redone.
I am picking the engine up Monday.
Everything looked great.
Had an issue with valve float.
PAC cut a set of custom springs to solve the problem.
Just received the 4" tubing and we are going to put on the 94mm turbo.
vinnybarber
cox's creek ky.
I had the gt47/88 on it
With the 94 we should dip into the 7's
The converter has never been right yet.
But we think we have that worked out
GT RO
GRANDE PRAIRIE A.B. CANADA
Update,
Very curious to see if you will be able to spool the 94mm with a 3 valve .best of luck & keep us posted . Come on 7's !
vinnybarber
cox's creek ky.
The off and on rain stopped.
So I got to pick this up
Who has the best price on brisk plugs
Brisk are expensive no matter where they come from. I've not seen anyone really be cheap on them.
if you need the
3VR14S, I have a NIB set that I could sell you for $110 shipped.
