Corpo
I
mines came with a hole that goes into the engine bay.
Which hole I mean
I personally would run the line through the inside of the car where it can't be seen, nitrous is non-flammable and to say it's unsafe makes no sense to me. Pop a line worse case scenario you get high... big deal. What are the odds of the line popping inside the car compared to being under it and exposed to the elements?
I assume you mean the peice on the right ?
How many psi is the one you use ?Yup. Mine came with 2 burst valves. I used the smaller one.
The burst unit pictured above says 3000 psi . on it that I have .Man it's been 2 years since I put it in, I couldn't tell you. Put it this way tho. I have a black car and it sits in the sun in 100 degree southern weather all day at work and it's never burst. I've seen the pressure as high as 1600psi in the bottle.
Chris can you post a pic of your trunk setup?
Let me dig some up, I have some of the whole process as we were making it all...
