Nitrous install question
05stroker
Never enough power guy!
Bullard Tx.
Next questions
1. Is there a special blow off valve that needs to be used with a blowdown tube ? The blow off valve on my tank doesn't have a threaded to to accept the fitting for the blow off tube .
2. The tanks I have is manufactured by Luxfer and has a Sherwood valve . I have seen online that the Sherwood valve will only flow a 100 shot or so . Is this a low flow valve ?
s8v4o
I personally would run the line through the inside of the car where it can't be seen, nitrous is non-flammable and to say it's unsafe makes no sense to me. Pop a line worse case scenario you get high... big deal. What are the odds of the line popping inside the car compared to being under it and exposed to the elements?
Outside of the car is easier IMO. There's nothing wrong with running it on the underside of the car. I ran mine side by side with the fuel lines. You don't even know they are there. Doing so makes it very safe and less likely to be damaged.
05stroker
Bullard Tx.
pics
Tank and all
picture.php
3000 psi blow off valve
picture.php
Blow off removed
picture.php
picture.php
TheKurgan
Florida Keys
Your blow down tube screws right down on top of that. Just stick the burst tab in there and screw on the blow down tube.
TheKurgan
Florida Keys
How many psi is the one you use ?
Man it's been 2 years since I put it in, I couldn't tell you. Put it this way tho. I have a black car and it sits in the sun in 100 degree southern weather all day at work and it's never burst. I've seen the pressure as high as 1600psi in the bottle.
05stroker
Bullard Tx.
The burst unit pictured above says 3000 psi . on it that I have .
Chris06GT
Dragging LS A..
Alabama
TheKurgan posted a nice link there...that's the one I used!! I also have 2 bottles in the spare tire department, along with a battery box...
