Charlie Sheen
Armed and Hammered
...One thing is for sure.. SYT WILL LIVE!!!!..
Wanna race to the 11s?
Ok...is it leaking 11% on one hole only? Was the engine warm or cold?Cylinder 8 was losing 11%, 4 was losing 4%. This is the plug from #8...
View attachment 3056 View attachment 3057
(Ted's talking, I'm typing...)
This is the MMR block w/about 6k miles on it. Plugs are 6 months old, injectors are less than a year, about 25 - 30 1/4 mile passes. Any guesses before we rip it apart? With this amount of leakage, is it safe to drive the car around town/freeway? Does this thing really have to be torn down again? How do I fix it? Can it be tune related? Why would #8 go lean and not the others? Am I really fucked?
[/Ted]
Only 11% when warm. Run a compression check on the engine then do a pressure test on the cooling system.
Thanks for the info stud.. will try that soon
As of today Went for a ride and tried to start the car and again it crancked over but didnt fire up. Again I had to step the gas peddle all the way down then it fired up and bam the puff of white smoke that smells like un-burnt gas! While driving I got a p0353 and cleared it and 30 min later I got that AND a p0352. It looks like the idea of me driving around nicely for a while is out the door. Once I get these other tests done I have to find someone to do the work.. or I "might" try tearing this shit apart again =-/. Shit
Man that sucks. IMHO I'd probably tear it apart and fix it or get it fixed before you keep driving it.
agreed.. I might take it out for the test today.. but other then that.. ITs to a shop or tear down at home.![]()
Ignition coil codes? Would they trip if there is trouble firing those two cylinders? First, the car doesn't want to start. Then you get bypass that smells like unburned fuel. Next you get coil codes. I'm wondering if you've got a headgasket problem or an ignition problem.While driving I got a p0353 and cleared it and 30 min later I got that AND a p0352.
