Young Punk Build Volume IV - The game needs change & I'm the mother *@#%en cashier
bigpappy33
11.17@126
Ft. Lauderdale, FL
Cluster looks sweet with that gauge. You think about putting the RPM gauge on the right side like on the GT500? Easier sight line when racing at the track too...
408wkash
hes got a really good point, id put it on the right too, still want to know what your going to do for fuel level and volts !!!
Matt D
S197 Pilot
Toronto,Canada
AsI sat in the car I relized the steering wheel blocks my veiw on the tach... so I will be going on the other side. Just wanted to see how they fit in. JPC did this awhile back on that silver turbo car.
I have to order up an volt gauge the fuel level sending unit I don't have yet for the fuel cell... not sure if im going to put one in or not.
DAV.TUK
Do the tachs fit really well in the holes for the speedo and tach?
08gt4u
looking great matt.im amazed you havent done something to that center console where the cup holders are.i had to remove it once the hole thing including the bottom plastic and it has some weight to it.
05yellowgt
Dayton, OH
I bet you could always use the intercooler connector to run an electric water pump Matt. I'm not sure if it would handle the amperage of one all on it's own but you could at least use it as the key power on source to activate the relay. Just one less thing to have to rig up.
Do you have a date in mind of when you might fire her up for the first time? It looks like once you get the misc. fuel components hooked up you could fire up with open headers in just a day or so.
Matt D
S197 Pilot
Toronto,Canada
I wish they made an electric water pump for the new 5.0.... the thermostat housing is now a bit differn't then before. Im hoping to get it running in a week or two when the rest of the stuff arrives. Open headers dam right lol
Matt D
S197 Pilot
Toronto,Canada
Im thinking about it.... for track days there is a bunch of things i can remove if I want lol...
carpet, Center console, passenger seat / rail etc
08gt4u
what did the kirkey seat weight it in with the brackets?i use the racing seats that look like kirkeys but are plastic with corbeau sliders and mines weight 24 pounds.
s8v4o
Wrong sub forum Matt :roflmao: Just messing with ya since you'll be rolling with a 5.0 now and not a 4.6. I know I know, but it's a 2005 right? lol
RRRoamer
Damn impressive Matt! Good luck getting it all up and running. I was a bit surprised when I first read you comment on cruising around in the summer with the heat cranked! And then I looked at where you are from and it made a bit more sense to this Southern boy!
