tylerxfire
I'm sure that will work, but what you want is that SLICK AS GLASS finish in the end. That is achieved by wetsanding with at least 2000 grit and buffing. Also, wet sanding between sprays gets the trash out so achievement of that slick finish is attained.
Good luck and PM or post if you need anything. Like I said, you really can't screw this up, but you will need some patience and diligence to gain the desired outcome.![]()
thanks, ur right i do want the slick as glass finish..im gonna wetsand between coats...ill have to buy some beer and chill out and just do it right
..id rather it take a little longer to look perfectdid u wetsand between coats of clear also? and about how long u think between coats of the vht did u wait to sand and also between coats of clear if u did sand between coats of clear
