3650 to 6060 swap done
gil_t2
Love Nitro in the Morning
Northern Va
I am about to swap mine. i have a question, did you install the reverse lock out? if not, are you having problems going into rev. If you did how is it done.
thanks
bigray327
League City, Texas
You don't need to install the lockout harness, which is just a pigtail that you can connect if you want the car to go into reverse a little easier. It's fine without it, so I didn't do it on mine.
gil_t2
Northern Va
I have a Coast DS, They told me to cut it down 1". I read another post on here, and they did not cut theres down, and they say it works fine, What do you think?
lito
Caracas, Venezuela
I have the part number of the pigtail somewhere, I just installed a switch I turn on when I parking the car.
thanks
I didn't hook it up. It's a little harder to get in reverse but not a big deal. I did weather proof the connector in case I change my mind.
bigray327
League City, Texas
Mine fits fine, but it's sized for a GT500. I suggest you install the driveshaft, and make sure you have at least an inch of play in the splines.
SherrodMustang
Montgomery, Alabama
Hey Bruce, what bolt did you use here for the swap? Doing the same swap coming up and I have the shifter pins, but was unsure on the bolt to the arm to the trans. :thumb2:
Thanks
picture.php
Thanks
picture.php
Sorry, don't know. I'm pretty sure it came with the shifter. Probably a M8x1.xx
Flapjack
Lunatic engine swapper
Colorado Springs, Colorado
I ran w/o the lockout for 2 years... just took a little more effor to get into reverse.
Then I installed the MGW GT500 shifter and couldn't shift into reverse. For whatever reason, I needed to have the lockout engage. It was pretty simple to do and to be honest, is much nicer shifting into reverse with it.
gil_t2
Northern Va
Is there a thread somewere with instructions? What parts do i need? (for the reverse lockout)
I have an MGW coming next week. Looks like I need to hook up the reverse soleniod. Do you remember what wires it gets hooked into?
Is it WPT-494? It looks like a standard delphi weather pack connector.
lito
Caracas, Venezuela
Anthony05GT
Maryland
Bruce, nice job bro! What's it cost to do this swap? I guess a take off trans would be the best priced unit.
I paid a good deal more than this but here is where mine came from.
http://www.lapointauto.com/ Do the search and it comes up at $1600 before shipping
The rest of the parts are available from horsepower1 on ebay. figure about $150 for the crossmember, shifter, and boot. If you already have a 26 spline clutch then you are all set.
