What's the stock bore of an OEM GT throttle body?
I believe its 50mm
I believe its 50mm
Im pretty sure the stock GT is 50mm, the stock GT500 is 60mm, and the FRPP is 62mmlike 55mm or something like that,
nj isnt the frpp a 62mm tb not 60.
Nope its way smaller... Night and day difference.. Ill take pics if you want to compare...Really? Geez, I've put off getting a regular GT500 TB like you did cheap from CJPonyparts because I thought they were the same 60mm bore.
You got it manI believe you guys.Thanks for the info!
Yeah to be honest the stock Manifold flows really well and except for the looks the Manifold probably isn't worth the money, but then again I am speaking strictly from an N/A setup from what I have read...
OEM Throttle body is Twin 55mm bores.
Stock tb is 55mm
Gt500 is 60mm
Frpp is 62mm
Its all good.
turns out they dont have a 5" x 3" coupling....Hose Techniques carries them and the t-bolt clamps as well.
LMFAO! I was using a truck load of no-hub's yesterday moving some 3" cast iron no-hub drains, made me think of my IC piping haha.... Im sure theres something lying around the TTE shop Jr lol. But yea, they dont make a 5"x3" reducing silicone coupling at all.... I could only find a 5"x4"..... So I think im going to do this...i cant find a 5x3 silicone reducer for some reason.. just use a NO-Hub, or Fernco lol
