Whipple 3V Pulley Poll -
What Whipple Pulley on your 3V HO system
  • 3.875
    Votes: 2 7.1%
  • 3.750
    Votes: 0 0.0%
  • 3.625
    Votes: 2 7.1%
  • 3.5
    Votes: 4 14.3%
  • 3.375
    Votes: 4 14.3%
  • 3.250
    Votes: 10 35.7%
  • 3.125
    Votes: 6 21.4%
  • Total voters
    28
Calgary, Alberta
As the thread states -I am wondering what pulley guys are using on their stock 3V blocks with Whipples.
Currently I'm using a 3.625" on an HO system, Gen 2, seeing about 8.5 psi on the dyno. I want to go to a 3.5". But want to be safe. I know a lot is based on the tune. My car has been dyno tuned and will return to the dyno if I install the a smaller pulley. (current ratings 387rwhp, 390rwtq mustang dyno)
Also if anyone has a 6 rib 3.5" whipple pulley for sale I'd be interested, I've been keeping my eyes on the classifieds with no luck so far.
BlownAway05
still too slow
Orlando, FL
I've ran a 3.5" since I've had the kit on. Saw just over 10psi when I got it tuned. Stock exhaust, stock long block.
Riptide
Will work for Mustang.
Montucky
8.5psi and it only makes 387whp out of a gen2 kit?
Is that normal?
69Mach1-409
South Jersey
I have the 3.375 and she's seeing 8-9 in the summer and 10-11 in the winter. Not sure weather mine is a gen I or II though..
Calgary, Alberta
Is that normal?
I did request a conservative tune, I don't know my A/F or timing numbers. I have also been told Mustang dyno #'s will be lower vs. dynojet (10%ish). If thats accurate it would be closer to 425whp ish but I havent ever had it on a 2nd dyno to confirm.
69Mach1-409
South Jersey
Mustang Dyno's are lower (not sure what %) and alot of other things can skew your Dyno numbers. (Tire pressure, Temp, Humidity, Altitude, Dyno tech, etc)
StangPower05
"Pony Up"
NY
When i was stock block with my GEN2 Whipple H.O running the 3.500 6 rib pulley i saw the full 10psi that the pulley is supposed to make. That was also with FRPP HotRod Cams and ARH Longtubes. My car put down 480rwhp and 460rwtq on a mustang dyno.. And the tune was super safe with afr's in the 11.5-11.7 range at WOT. You'll be fine with the 3.500 on the stock bottom end for a while, but just know, it will let go sometime..
Charlie Sheen
Armed and Hammered
Infernum ubi sum
Is all your exhaust stock? I must be seeing less boost based on the bassani x pipe and corsa exhaust and my altitude.
With coated JBA shorties/stock cats/Bassani X/SLP LMs or stock mufflers I saw a solid 11psi. Now with the same JBAs/ o/r ProChamber/stock mufflers I'm still seeing over 10.
2006gtmike
South of Philly
Dyno'd On Mustang Dynamometer
Running 4.00" Pulley
6.1 LBS MIN
7.1 LBS AVG
7.7 LBS MAX ...401 RHP 391 RTQ
Now I'm running a 3.875".
Not sure where I'm at now.
Any estimates?
jmn444
I've not heard of people goin boom with the frpp tune and the 3.25.... But I'm still expecting it to happen someday!
GT E UPP
Toronto, Ontario, Canada
Whipple-HO Intercooled, 3.25", 11 PSI, 538 RWHP ( Mustang Dyno)
Steeda-Whipple 10 Rib Belt System , Stock Internals and having Fun !!!
