Still running stock panhard with it lowered even stock setup the rear to the left alittle. You need adjustable panhard bar
Well, you can't start to fix things until everything else it right. So it seems that you'd want a panhard before you started to screw with other things. Only makes sense in the world of troubleshooting...![]()
Technically I should have one regardless with my 1.5" lowering springs.
If this doesnt fix it, the UCA and alignment will be next.
Here is to hoping the BMR Panhard bar fits with the Shelby diff girdle
Is your front sway bar still on the car?
Sway bar is stock and untouched up front
Install a spool. No way one side can move without the other.
I thought that... But I have had the alignment done just last year after I was lowered. Everything was adjusted to spec
