HELP ME
Kuro!
Banned
Austin, TX
When I first broke off a spark plug in my head the removal tool wouldn't work.
Pop off the valve cover, front cover, ziptie the timing chain and pop that bitch off. It's like a 2-3 hour job.
05stroker
Never enough power guy!
Bullard Tx.
If you are going to try to crank it with out pulling the head , I would disconnect the injectors and coils and turn it over with the new plugs out first by hand several time and then with the starter. If I was missing that much of the plug ( never seen one that far gone form running the car ) I would be pulling the head. JMO
Good luck and keep us posted.
Kuro!
Banned
Austin, TX
That's what i'm saying. That is a sizable chunk of plug missing, something that size doesn't normally just disappear.
alexthejew
Jewish and lovin it.
whats a good wire to tap into for my gauges so that they are only on when the car's acc are on? before i tapped to the hot side of the fuse box and they drained my battery lol.
G.T
Earth
Chck the fusebox in the passenger side kickpanel and compare to the photo below
using a fuse tap into A or C, you'll get a switched +12V circuit that turns on and off with the rest of your accessories
UltraKla$$ic
PERENNIAL WAXXER
Louisiana
:booring: Well? Is it running? Blown up? Scrapped? :wtf:
RUDE!!!!:nk: That Procharger is too sweet to not follow up on!!!!
Update please.:asshat:
alexthejew
sorry. my buddy and i are sitting on my couch writing a tune. car turned over yesterday, but wouldnt hold idle, so were working on that. then datalogging.
alexthejew
because you cant buy knowledge
wont idle, because i have stage 2 thumpr cams, a procharger, charge motion deletes, a bigger throttle body, and cmcv deletes.
it needs a tune. i was hoping that my tune would be aggressive enough so that i could run logs carefully anf tune from there, but were writing out own startup tune, and well be running logs and adjusting tomorrow. im excited. havent driving this thing in a week.
Kuro!
Banned
Austin, TX
Did you put in the cams before or after the procharger install, and did you change your injectors?
