1989 LX hatch rolling chassis caged/ mini tubbed
john boschma
You don't scare me!!!
64k original miles vin # 1FABP41E1KF118036
it has the best of the best.
never any accidents. the car is rust free and straight. the paint is nice and shiny but not perfect. scratches and chips here and there.
chassis work:
mini tubbed
10 point chromemoly cage will certify to 8.50's
thru the floor sub frames
upper and lower torque boxes re-inforced
chromemoly tubular front clip
removeable one piece front end
rear suspension:
8.8 housing narrowed 2 1/4 on each side,straightened and welded tubes
moser axles 35 spline 5/8 studs 5 lug
moser C-clip eliminators
moser spool
moser driveshaft yoke 1350 U joint
5.13 mikronited pro gear
wolfe double adjustable uppers
wolfe double adjustable lowers
wolfe anti sway bar
strange double adjustable coilovers
wolfe spherical hiem in axle
earospace billet drag brakes
front suspension:
upr tubular K member
upr tubular A-arms
upr coilover kit
hyperco 125#coil springs
upr billet caster/camber plates
strange 10 way adjustable struts
earospace billet drag brakes 5 lug
flaming river manual rack
flaming river steering shaft
steeda bumpsteer kit
Electronics:
painless wiring toggle board ie.starter,ignition,electric water pump,electric fan,line loc.
MSD digital 6 plus igniton box
autometer pro comp ultra lite fuel pressure
autometer pro comp ultra lite oil pressure
autometer pro comp ultra lite water temp
autometer pro comp ultra lite volt meter
2 autometer pro comp ultra lite vacuum gauges
fuel system and electric:
plastic 10 gallon fuel cell
weldon fuel pump
-10 line to pump and filter
-8 line to front
taylor aluminum battery box
optima red top battery
flaming river battery shut off
interior:
kirkey aluminum race seats
rci 5 point race harness's
no carpet
no door panels
no headliner
wheels and tires:
greg weld 15x3 front
greg weld 15x10 rear 4.5 bs
moroso ds-2 front tires
mickey thompson 28x10.5-15 et drags rears
i'm sure there is more but you get the point.EVERYTHING IS BRAND NEW ,NO STRIP TIME EVER.
this car has had extensive work done to it, and i have made it as lite as possible. this car only wieghs 2660 lbs. with driver.
and that is with all the original steel hood and hatch and all the glass. no lexan.
i'm located on the illinois/wisconsin border just north of rockford and about and hour northwest of chicago.
if you have any questions please email me at [email protected] or call me at 608-346-4015 thanks john
PRICE $10,000 o.b.o
for all the build pics of the car go here.
http://s271.photobucket.com/albums/jj127/killerkx327/
