Like said your electrical fuel pump is in the driver side. The passenger side just has a venturi siphon to pull fuel over to the driver side. It is referred to as a jet transfer pump, but it is not really a pump.
Ok, i just shipped a new FP from the US and it didnt solve my sever fuel problem, this is what i have:
First i am in Beirut/Lebanon i have GT 2005 with 117k on it that was shipped from the US. I have a major problem on acceleration and on WOT with the fuel delivery as shown in the video here:
http://www.youtube.com/watch?v=5pMCJANgKvA
I shipped a new FP and installed it but the problem remains the exact same one.
I sat in the back of the car with a friend driving it and tested the voltage coming to the pump on load, it reached maximum 9V (thats a problem) .
I did some pids logs :
Fuel rail pressure on WOT: fluctuating severely between 0 and 60psi
Fuel pump voltage: between 5-9V maximum (problem)
VOM tests with key on:
TPS showed 5v
FRPS showed 5v
FPDM 12v (i read that it should be 10.5v)
Fuel Pump showed 4v
Battery 13v
ALT 14v (on idle)
Ground test:
12v (no leaks)
10v at the valve cover ground check (is it normal here)
Vacuum test:
no leaks
Inertia switch test passed (i connected the 2 wires and car runs)
New fuel filter, MAF cleaned 2 times, FPRS hose removed it not wet and doent smell fuel.
I logged battery voltage pid and it goes down to 10-11V on load, something is sucking power (here is the problem)
2 days go the problem got worst:
The car now stalls at 3000-3500 RPM it was on 5000-5500 RPM last week.I could reach the rev limit on WOT while car is parked, now i can only reach 3000-3500 RPM
If i floor it slowly in park mode i can reach the rev. limit, if i WOT it fast it stalls on 3000-3500 RPM but engine never shut off.
Changed to a new battery today, no changes.
Changed back to the old Alt. today, (i have a PA 130 amp + 4g wire that i also shipped to my country and it has 4k on it since i bought it) no changes.
Ran a voltage test on battery and PA Alt: 13v on key on, 13.88v on idle, 14.1v on 2000 rpm.
Ran a PCM to FPDM wire test (#12,#21) both wires pass ok.
Ran an FPDM test, 12.66v on idle, voltage fluctuates between 13v & 13.33V on WOT.
Ran a wire directly from FPDM to FP, 12v on key on. / fluctuates between 3v-5v on idle. / fluctuates between 4v and 7v on WOT ---> rpm never reached more than 3500 on WOT<-----
Any ideas what else should i check please?
Thank you.
