2005-09 Mirror Painting
DanB
Niles MI
I am trying to think of a way to do something about the horrible side (truck) mirrors Ford put on my Mustang. Sadly all the after parts manufactures quit making replacement color matched mirrors.
Has anyone tried to sand and prep the factory mirrors for paint? My thought is buy a set, start sanding with, I don't know, 800 grit then work my way down to 2000 grit and hopefully get s smooth surface and then paint them.
Has anyone tried this? And painters out there think this is even a viable option?
Thanks
Dan
GriffX
Rural Germany
I painted the "upper insert" in the color of my stripes and the rest black. I decided not to sand the structure off, makes it much easier.
86GT351
Sunny South Florida
Thanks
Dan
Manufacturers stopped the color match years ago due to aging inventory sitting on shelves. Everything comes black and gets painted to match as needed.
Miker
USA
Thanks
Dan
I like the way the mirrors look on the 2005 forward Mustangs. The mirrors blend well with the entire look of the car.
I have always wanted a Challenger and to me the mirrors on that vehicle are hideous. The Mustang mirrors don't look like a stuck on afterthought like the Challenger mirrors.
Opinions are like assholes. Truck mirrors? Blasphemy!
MrBhp
I wonder if I can fit these on the mustang. Asking for a friend.
CrashDevine
York
Thanks
Dan
Just got done painting mirrors and they look good
Good
cavero
NoVA
They still make these inserts for the OEM mirrors,
but the '10-'14 mirrors not a bad idea. I can't find a whole car shot, but found a thread that goes over it here:
cavero
NoVA
rocknrod
Wake Forest, NC
I like those raxiom side mirrors with the signal built in. But when I watched an install video it showed the wiring was not thought out very well.
San Tan Valley, Arizona
I went through auto body class at the local community college when I was a Senior in high school and I've painted quite a few plastic pieces on various cars over the years with that base knowledge guiding me.
That kind of plastic responds well to just a light scuff and multiple VERY LIGHT layers of paint. I would not recommend 800 grit as it will leave deep gouges in the plastic and as you work your way into the higher grits you will be surprised to see how deep those scratches actually are from the 800. That is, unless of course, you're going to use a primer that fills scratches ( primer filler is what it's called, go figure ) but on these plastic mirrors you don't really need to. Make sure you use the paint that is actually formulated for plastics.
