2006 GT line lock
Going with a line lock and considering there are a few companies to go with, with prices varying, I didn't know what the pros and cons are. SLP and Hurst are two big names. Why the price difference? Anybody use one?
RED09GT
Equal Opportunity Offender
Kelowna, B.C. Canada
I use the SLP. It was an easy install and holds the brakes just fine, don't fall for the companies that claim it messes up the ABS and try and sell you 2 solenoids.
Only times I've fucked up a burnout since getting the linelock is when I've forgot to hit the tcs button.
awesome autocorrect malfunctions brought to you by tapatalk
MikeVistaBlue06
Inventor: Asshole Points
Richardson TX
^^What he said. Just installed mine. Not that bad of a PITA and the kit is made for our cars.
HTH
Mike
XJCasper
Yelm, Washington
Aaahhh...
I was wondering the same question, but with so much more on my plate, have not searched the topic.
Thank you for asking...
Riptide
Will work for Mustang.
Montucky
Only hard part with the slp is drilling to mount it. I had to use a 90 degree angle attachment and had to cut down bits with a dremel. Its a tight fit.
Sent from my iPhone using Tapatwat
phattyfat
Connecticut
Just put a granitelli in an 08 and it works awesome. It's more expensive than most of them but install took about 20 minutes. It uses flex lines and mounts in the front above the abs block. I likes that most because where the others mount it's a pita to get to and I have all my nitrous solenoid a and lines mounted there as well as an oil separateter. Just some food for thought.
swflastang05
Back for More
N. Ft. Myers, FL
I also use the SLP kit, reasonably priced, good fit, easy install and works great, what else could you ask for? Zero issues with ABS.
RED09GT
Another option is to use a punch to mark the hole from the engine bay, then find the punch mark and drill it from the wheelwell after pulling the liner.
07 procharger
Addicted to modding
Red Deer Alberta
I almost did this same thing, but wrestled with the drill and finally got the hole drilled. I almost removed the valve cover as well. 90 degree drill would have really helped.
429244
I use the SLP kit. The only thing I did not like was the button. I added a momentary-on button to activate the line lock. As for the above, I just installed my kit this year. It came with self-drilling screws. I ran them in with a 1/4 inch air ratchet and it worked great.
Riptide
Montucky
The install is easier on 07+ cars.
MikeVistaBlue06
Richardson TX
Used a punch to hit mine a few times to get a dent started. Then an air ratchet and the self tapping screw, some ummph holding it to the metal and in she went. I only put one screw in it. Seemed tight enough to me with just one.
