2006 Mustang GT DIY Front & Rear Brake Guides?
blahdo_s197gt
California
Does anyone happen to have any Front & Rear DIY Brake guides for an 06 GT. I've tried looking online and all I came across was a youtube video for the rear brakes. Thanks for your help guys!
MADGT
USA
Agree with YouTube...that's what I used as a guide when I did mine.
05stroker
Never enough power guy!
Bullard Tx.
The fronts are pretty easy. Just remove all the bolts and use a c clamp with a piece of wood or (like I use) a piece of 1/4 alum plate about 6 inches long to compress the caliper pistons. Watch how everything comes apart and it will go together the same way. If it is your first time, just take pictures with your phone as you disassemble .For the rear it is the same except you need a special tool that you can rent from Autozone to turn the rear caliper pistons in. Keep in mind the drivers side and pass side turn opposite directions. I cant remember wich is wich though.
