def67
Me^ Stuff I say>
How old is your blower?
Well at least you get to make improvements!
Since the VMP gen2 blower makes loads more power ( another 2.3 psi boost for the same pulley size).... u don't want to blow the motor up, or pre-detonate with more boost, and ur lousy 91 octane. IMO, I would increase the blower pulley by 5-6mm, and drop the boost back down to where it is now. Then u will (a) eat LESS hp off the crank..for the same boost u have now. ( b) heat from the new gen 2 blower, pre-ic, will be way down. Gen 2 puts out way less heat for the same psi. You really don't require the venom cooler.
I think if it was me, I'd be inclined to buy a complete new VMP TVS-2300, gen 2, install it..then deal with the existing gen 1 blower..after the fact. ( IE: get it repaired, sans venom cooler, then sell it). You may well have more than the coatings falling off, there could well be nicks and dings in the rotors, which would put em out of balance, or render the rotor's un-repairable.
BTW, when u lost plug #7... baffles me why it would sound 'normal' on the 2 hr drive home.
Why not put a bigger higher psi pulley on the lower and lower on upper and change the psi combo around. Kinda like the 03 cobra guys do. I live close to steigmeier so if you need to do anything to help you out let me know.
I really don't think their cooling system will provide you much in term of performance.
The best it would do is cool the bearing area, not the case itself.
Might want to skip that one as you are going to a more efficient blower anyway.
Jimbo, the Venom Cooler ties into your supercharger cooling system and not your engine cooling.
Would did they price you a gen2 case for
I stand corrected. Ok, now you are diverting coolant from your IC.... to run your venom cooler. ur iat's will increase...since your flow level through the ic is less. There's no free lunch here. Run the venom cooler idea past VMP...you will get an earful.
$1500 for a case is deeee cent. I wonder what Justin does with all of his money, I just sent him like $1500 USD for a few parts - not even a supercharger! Probably has to give it all to Obama. I wish him the best, especially if he's still working out of his house.
