Well, I finally installed my shifter last night. I have very little mechanical experience, so it took me about four hours.
i jacked the car up and set it down on four plastic ramps.
i had the old shifter out in no time.
next, the mgw clam shell upper and lower went on fairly easy to my surprise.
i then installed the top shifter piece and thats where i ran into a little trouble. the hex head bolts that hold it on did not want to go in very easy. they had some "yellow" looking stuff on them which i though must be some sort of lock-tite. i went ahead and put a little blue stuff on them to be safe.
once i got them tightened down, the heads started stripping out before i was satisfied that were tight enough. i had to stop and leave them as they were.
i figured this piece needs to be the tightest piece of the whole assembly, so im hoping like hell i got it tight enough to stay put.
i hope i never have to take it off to grease the internals again because ill be screwed and have to try and drill the heads off because im sure they wont come out without completely stripping out.
the boot was a bitch and i was prepared for it. i was about to give up, but then got a nylon trim tool that looked similiar to a small chisel i got at harbor freight and somehow managed to get that bottom seal on. the other two seals were cake.
so next, i moved to the back bracket and that that would be simple, but that turned out to give me a little trouble. it was hard to hold the bracket up with the rubber pad under it, but i finally got it to "stick" on the thread while i got one of the nuts starts.
it was hard as hell to get the rubber washer, metal washer, lock washer, and nut all started in a place to small for both hands to fit. i finally managed but it wasnt fun.
after that, the shift handle was pretty simple and then got the console back in and took it out for a test drive.
looking back, im a little worried and thought i may have been better off letting it sit a couple days to let the lock-tite set up before i started driving it around.
anyway, it was a little different that stock and i accidentally selected the wrong gears a few times from it being a little stiffer and me not being used to it.
after about 30 miles, it seems to loosen up and little and i became more comfortable with it. things are still a little on the clunky side, but not as bad as it was stock.
one think i did note is everything was quiet for about the first thirty miles, then after that, i started noticing a little vibration noise. i cant tell where it is coming from. it doesnt sound like the shifter area, but seems to just do it when the car is in gear. when you push the clutch in, it stops.
ill have to do some more investigating next week when i get a day off.
