Bobby
turbo gt about to go fast
kit and options shipped $5,700.00 for base kit jurnal bearing
twin kit piping and headers
twin 62/65 billet wheel journal bearing
wire upgrade kit
60lb injectors
hightemp coating on all hot piping
two 44mm wastegates
one 50mm bov
Driver side Tubing From Turbo To Intercooler (2pcs)
Passenger side Tubing From Turbo To Intercooler (2pcs)
5 ply Custom Silicone Coupler Kit
All T-bolt Clamps For Couplers
Twin Turbo Custom Air to Air Intercooler
Custom Welded 50mm Blow Off Valve Flange On Intercooler End Tank
Driver and Passenger Side Turbo Manifolds, T-4 Flanged
3” Stainless Downpipes (Welded for o2 sensor and wideband)
44mm Wastegate Tube Extension for Passenger side
V-band Clamps For Each Exhaust Connection
Downpipes Welded With 2-Bolt Flanges To Adapt To Factory Style Mid-Pipes
Custom Oil Feed Lines / Drain Kit
calibrated maf and flange welded on
Custom Cone Filters
Custom Formed Aluminum Intercooler Mount / Air deflector
Custom A/C Line
Vacuum Line For Wastegates
Vacuum Line For Blow Off Valve
Tees For Vacuum Line
Hardware Kit
Instruction CD w/ Photos
upgrades
uncoated stainless xpipe and 1000 injectors for $400.00
high temp coated stainless xpipe and 1000 injectors for $500.00
polished turbo housings $55.00 each
turbo blanket $80.00 each
two triple ceramic blall bearing billet wheel 62/65 $500.00
two oiless tripleceramic ball bearing billet wheel 62/65 $1000.00
80lb injectors $50
fore innovations fuel system ask for pricing
special color for piping. ask for detail on price
more pics to come soon
wire upgrade kit
60lb injectors
two 44mm wastegates
one 50mm bov
Custom Cone Filters
Custom A/C Line
Hardware Kit
upgrades
80lb injectors $50
