2013 GT500 cast aluminum oil pan 8.5 quart
Vallee
Syracuse, NY
IIRC it's an oil level sensor? I could be wrong though, but I know even without running that sensor in my 05 I still have oil temp readings on my aeroforce gauge.
Yes I believe you're correct, a little research on the Internet confirms this is a oil level sensor. If it's easy to disable the PID via software then I think that might be a better option.
If I knew exactly where it needed to be I could tap the pan but since I don't, I may just disable it.
Boone
Automotive Enthusiast
High Point, NC
I'm trying to locate one of these oil pans. BOSS50 build going together this winter.
Steeda shows them on their website as "call for price." Not available though. Where do I go?
sportinawoody
Piedmont area , N.C.
Steve @ tasca. He is a vendor on here. Get it as the kit. Comes with longer bolts,pan,,pickup, and composite 1 piece gasket that serves double duty as a crank scraper. You won't find a cheaper price on Ford parts than tasca
BadPiggy
Hooligan Ahole
Knoxville, TN
Allrighty then... Steve @ Tasca it is. I'll add it to my build list.
I'm not 100%, but I think this part is discontinued. I vaguely recall another member looking for one and nobody could get it. If it has been discontinued, I'd go with a Canton, nice pieces.
Good luck in your search.
sportinawoody
BadPiggy
Hooligan Ahole
Knoxville, TN
Maybe they just don't sell a kit anymore. Can't see them discontinuing a pan or gasket. These things fail when you get a heavy handed oil changer that tightens your plug to 1000 ft//lbs
Edit: just checked, they don't sell the kit anymore, parts are separate. Shit I paid what they want for just the pan for the whole kit. https://secure.revolutionparts.com/...ne/engine-cat/oil-pan-scat/?part_name=oil-pan
Yeah, I knew it was something about the kit.
He should still call Tasca Steve and inquire, never know.
Scott
King City, Ontario, Canada
Here is Todd's (tmcolegr) thread on the Canton, as I recall he did have a couple issues with it.
http://www.s197forum.com/forum/showthread.php?t=74268&highlight=transmission+cooler
When I did my build the 2013 pan was not available and I went with Moroso part number 20548. Works well for me.
Boone
High Point, NC
I believe I've located the part numbers for the pan and gasket/windage tray.
DR3Z-6675-A $154.57 Oil Pan
BR3Z-6710-B $72.40 Oil Pan Gasket
I called Steve @ Tasca to confirm. Voice mail. I left a message.
Based on the issues I've read (thanks for sharing) with aftermarket "performance parts", the FRPP pan appears to be a no-brainer.
Boone
High Point, NC
Do I need the oil pick-up that came with the kit, or can I use the one from my '05 3V?
7R3Z-6622-AA $23.77 Oil Pick-Up
At that price, I don't know why I'm asking. It is a weeks worth of lunches at Taco Bell, though.
The pickup is identical to a 3v pickup.
As Bruce said, the pickup is the same part number as the 3v oil pickup. I used mine since I was assembling a new block, just left the old one on the old block.
