BruceH
BBB Big Bore Boss 322
See the bronze color and the circle around the edge, it's a bearing that is pressed in.
Technically speaking it's a bushing.
block was dropped off this morning! the said it didnt look to bad and will try honing it first. they will be using torque plates. so i wont know about pistons until they give me a call on the bad cylinder.
no, the .020 are hard to find but not custom. Will still take 3-4 weeks i'm told if i do the coated manley.
You can run standard bore pistons with that size bore. As long as the bores are straight at 3.555. I run 3.555 bore size with Manley 3.552 pistons. I have ceramic hard anodized Manleys in mine.Machine shop honed it to 3.555 to get rid of the bad spot.
Diamond fully coated pistons are $1150
Manley fully coated pistons are $799
Machine shop is holding onto the block until I get the pistons, then they will machine .020 over based on the new pistons. Supposedly the Manley pistons are pretty nice, havnt seen any reason at this point not to go with them.
.020 over bore is a standard size I thought didnt realize they were hard to find. When I bought my diamond pistons from the link above it has a drop down for bore size.
P/N 595520C-8 for a -14cc (9.51:1). This is the .020 over stroker production model? are these what you are looking for?
One difference between Manley and Diamond is the Malney pistons have a much thinner wrist pin, but you can get them upgraded depending on your needs. I run the 9310 pins with mine which are the top of the line for the Manley pistons. 9310 is harder than 4140 or 4340 whichever chromoly pins come standard with Manley pistons.
.003 is what Manley recommends on the modular pistons with moly skirt coating and .004 without. I see what you are saying about the pistons potentially being too small and by the time you have the cylinder honed to the ring specs the clearance would probably be closer to .004 which is a little loose when running the moly skirt coating.they are torque plate honing/boring,.003 is a little too much i think for clearance. id like to be closer to .0025. plus i want them to go a little deaper on that damaged sleeve just to be safe. since im ordering pistons i dont want to take any chances of the pistons being too small once they show up.rather go slightly bigger and have it bored to match with no issues.
diamond also has a upgraded wrist pin as well for an extra $19 per pin.
They come from Manley with the skirts coated ( which you probably know), I'm having them add the thermal coating to the tops. Wasn't real expensive so it should be worth it.
Next I'm hunting for bearings....
they come from manley with the skirts coated ( which you probably know), i'm having them add the thermal coating to the tops. Wasn't real expensive so it should be worth it.
Next i'm hunting for bearings....
