BruceH
BBB Big Bore Boss 322
Pistons are $650. Add the Boss rods for a total of $825. Shipping is extra. EDIT: Rods have been sold.
Pistons are for a 3.701" bore Big Bore Boss block. They are side coated, new, made from 2618 alloy, have valve reliefs that will work with 2v, 3v, or 4v heads, and come with rings, pins, and locks. Compression with stock heads is a little under 10.9:1.
Rods are 5.0 4v Boss rods. They are the same length as 4.6 rods at 5.933" and use the same size wrist pins and bearings.
Using these components with a stock stroke crank will produce a motor with 304 cubic inches of displacement. The main advantage over a stroker is that this combo will make an overbore motor instead the under square setup a stroker makes. It allows for faster revs and unshrouds the valves helping with airflow. It will work well setup na or with boost and would make a great foundation to build on for someone who is building their car in steps.
