tmcolegr
It's All About the Build
I took delivery of my Windveil Blue S197 GT Coupe in Jan. 05. Vehicle is equipped with a 5R55S automatic transmission and currently has 9,800 miles on it. My original goals, from the day I purchased the vehicle, were to (1) have a reliable, (2) driver friendly, (3) 500 – 525 SAE RWHP daily driver. So fast-forward a little over 4 ½ years. I have installed just about every bolt on mod possible that did not require modifying the factory long block. Although I have reached goals # 2 & 3 (drivability and 500 -525 RWHP), I wouldn’t consider the factory long block reliable long term at the current HP level. So plans this winter are to upgrade to a forged 298 CID rotating assembly using the stock 4.6L 3V aluminum block and heads. I do not plan on increasing RWHP above 525 – 550 max. as I do not believe the 5R55S is capable of reliably performing above that HP level. I also do not plan on any trips to the track – street duty only. I anticipate this venture taking 6 months as I will personally be performing all labor to R&I and D&A the engine, to include all required machine work of the original block – torque plate boring & honing, file fitting rings, etc. Planned mods will include:
These new mods will compliment my existing mods:
- JDM 298 CID Forged Rotating Assembly
- Kellogg Forged Steel 3.750” Stroker Crankshaft – 8 Bolt
- Manley H Beam 4340 Rods w/ARP Rod Bolts
- Manley Forged Aluminum Pistons w/Rings - .020” Oversize
- ARP 3V Main Studs
- Federal Mogul Rod & Main Bearings – std. Size
- GT 500 O-Ringed Oil Pump
- FRPP 8 Bolt Flex Plate – Modified for use with 5R55S Auto Trans.
- ARP 3V Head Studs, Harmonic Balancer Bolt & Flex Plate Bolts
- Comp Cams XFI VSR Stage 2 Blower Cams w/high load valve springs and steel retainers
- OEM Head Gaskets and One-Time use Torque-to-Yield Hardware (cross mounted main cap bolts & cam phaser bolts)
- TCI Billet Input Shaft
- JDM Custom Tune - 93 Octane Pump Gas
- Ford Racing Performance Parts:
- 4.10 Gears
- Cam/Valve Covers – Powdercoated Black
- Borla “Stinger” Axle Back Exhaust
- Kooks:
- Long Tube Headers w/Stage 8 Locking Bolts
- Off Road X-Pipe
- Autolite: HT0 Spark Plugs (Gapped @ .030”)
- C&L: “Racer” Intake Tube w/Bump Hose & Clamps
- JDM Engineering:
- Saleen 2.87” (14.5 PSI) Supercharger Drive Pulley
- Gates K061073 Micro-V Belt
- Saleen Series VI Supercharger
- Saleen GT 500 Dual Fuel Pump, FPDM & Harness
- 03-04 Cobra MAF Sensor Conversion/Pigtail Harness
- Cold Air Intake w/K&N Filter
- Vacuum Upgrade Kit
- Lowered Prothane “Bullet” Engine Mounts
- OEM GT 500 Throttle Body, Spacer, Bump Hose & Clamps
- Intercooler Relay Kit w/switch
- Aluminum Transmission Overflow/Catch Can
- SCT: Excalibrator 2 Tuner
- Granatelli BA-2400 MAF Housing w/Sensor
- Sieman Deka 60 lb./hr. Injectors w/conversion harnesses
- Canton Aluminum Coolant Reservoir
- Afco GT 500 Pro-Series Dual Pass Heat Exchanger
- Canton Aluminum Power Steering Reservoir
- Spal: (2) 5.2” Heat Exchanger Fans w/Relay & Temp. Switch
- Be Cool: Aluminum Radiator
- TCI:
- StreetFighter Torque Converter (3,000 Stall)**
- StreetFighter Ratchet Shifter w/B&M Brushed Aluminum Shift Handle
- PMP: Line Locks w/Jeg’s Solenoids
- MSD: Launch Master 2 Step
- Meziere Enterprises: Electric H2O Pump w/V10 (5.5”) Idler Pulley & Relay Kit
- Thump RRR Racing: Billet Aluminum Belt Tensioner w/76 mm Stamped Steel Idler Pulley
- Metco Motorsports Solutions: Drive Shaft Safety Loops – Front & Rear
- BF Goodrich:
- g-Force T/A KDW NT 255/45ZR18 Tires – 769 RPM (27.0”) @ 45 MPH - Front
- g-Force T/A KDW NT 285/40ZR18 Tires – 771 RPM (27.0”) @ 45 MPH - Rear
- Strange Engineering: Adjustable Rear Shocks
- Steeda:
- Billet Aluminum Lower Control Arms – Rear
- Billet Aluminum Sway Bar Mounts – Front
- Competition End Links – Front
- Control Arm Bushing Kit - Front
- Magnetic Engine Oil Drain Plug
- LPW Racing Products: Extra Low Profile Ultra-Pro Cast Aluminum Differential Cover
- BMR Fabrication:
- LCA Relocation Brackets - Powdercoated Black Hammertone
- A-Arm Support Brace - Powdercoated Black Hammertone
- Upper Panhard Rod Support - Powdercoated Black Hammertone
- Adjustable Panhard Rod w/Poly Bushings - Powdercoated Black Hammertone
- Progressive Lowering Springs (1.25” Front /1.50” Rear) – BMR Red
- Adjustable UCA w/Poly Bushing - Powdercoated Black Hammertone
- HD Sway Bars – Front & Rear - Powdercoated Black Hammertone
- Rear Sway Bar Billet Aluminum End Links
- HD Boxed Sub Frame Connectors - Powdercoated Black Hammertone
- Camber Adjusting Bolts
- Ford:
- GT 500 Strut Tower Brace – Powdercoated Black Hammertone
- GT 500 14” Front Brake Kit
- Hawk: HPS Brake Pads – Rear
- CHE Performance Products: Axle Brace
