47lb injectors/405 fuel pump/ 05-09 mustang grill
Houston tx
OEM gt500 47lb shorty injectors.110+Shipping Used for a year, I modified my fuel rails alittle to make them work.. Before that I believe they where on a gt500 for 7k miles. Some how I lost a o-ring on one of the injectors but can be easily replaced.
S&h single 405 pump. 155+shipping Also used for about a year. Work just fine with my turbo kit on 10psi. You will need the wire kit because i kept it for my new fuel setup. Jermey sells it for 35$ found here http://www.s197forum.com/forum/showthread.php?t=76458&highlight=405
Stock gt grill 50$+ shipping. Fog lights w/ only 1 bulb 50$+shipping they dont have the attachment rings to go on the grill.
joswo1980
What kind of modifying are we t alkn about to make these injectors work
Houston tx
I bent the tabs of the fuel rails up and then used an L bracket to hold it down. The L bracket put presssure on the tabs that are bent upward.worked for me for the year i had them no problem. I upgraded my fuel rails injectors and pumps. I can send you my fuel rails as well for 30$+shipping if you dont want to bend your tabs. If your intrested
That is a smoking deal for the fuel setup, cant believe it's still here! I will offer a discount on the wire kit you need to run with it to who ever buys it.
