645 rwhp quater mile times???????
2011Black5.0
2011 5.0 645/510 .curious to see if anybody made this kind of power and ran there car to the drag strip I'm going Friday I have to pick my car up this week still at jpc any I'm hoping to go some kind of 10.50 or better if I can hook
2011Black5.0
Wow oh my car weighs 3700# with me
I was thinkin around 132-135 mph
05mustang_TT_charged
Because Race Car!!
LSU Country
My car was 4040 lbs with me in it. I did make those numbers on pump gas, 4R70W, and Mustang Dyno if that is any help. I would say around 135 mph would be about right but probably faster.
topbliss
South Jersey
my buddies 2011 5.0 automatic set up by Evo just ran 10.17/139 with DR's and a soft launch with 667 hp
psfracer
billy badass
Valencia, CA
Do you have a manual or auto? What gear and tire?
At 604 rwhp @3450lbs, 28 tall tire with 4.10s, best mph was 134 mph.. I think at 650rwhp, with the right tire and gearing, you should hit 135 or so.
Greg Hazlett
Stepping on the Pink Bus
Official Vendor
Chesapeake, VA
Everybody will read this thread but won't give me any info
Way too many variables...like others have said, gearing, tires, atmospheric conditions, stick/automatic...how much experience do you have racing? How much stick time in this car with the new power? What track and how well is it prepp'd?
If you want info you have to help us help you.
2011Black5.0
3.73 gears I'm talkin like getting 1.5 60 ft slammin gears power shiftin I think it should go 10:50 or better shouldn't it?????? For supension I have pan hard bar uca qa1 rear shocks sway bar delete stock lca
psfracer
billy badass
Valencia, CA
Well the DA this time of year at ATCO is truly "mineshaft" air. That combined with a good tire, you should be in the 10.00s area, and if you can shift very well, 135+ mph is good for high 9s.
2011Black5.0
So will the stock controll arms break with that kind of power or will it cause the car to wheel hop to the track.I had steeda lca before then I broke bushungs twice so I was just gonna run the car with stock control arms
Diabolical!
Zapp Rowsdower
The stock LCAs won't break, but they will flex like wet spaghetti noodles. I'd consider a rod-end LCA instead of poly bushings. I blew out a poly bushing on an aftermarket LCA and replaced them with rod-ends instead. Now my car stays firmly planted on launch and I don't have to worry about blowing out another bushing.
