Pics.
Pics.
You have the 8 rib setup correct? Is that the same belt from before?
If it wasnt like that before and you have had the blower and mount off recently I imagine it has something to do with that. I would check the tq on all the mounting bolts etc. Doesnt look like its going to be an issue though based on it being a smooth idler.
You can see a gap where the yellow arrows are. I think it goes to the triangle piece for the idler into the timing cover. Good luck.
If you're trying to torque them down with the supercharger and belt both on, it probably won't work due to the weight/tension. I would recomend removing both (I know know bad it sucks) Don't over torque those bolts either, I broke one of the idlers off in the timing cover. Horrible experience.
I would def slip the belt like off the water pulley or something to relieve the tension and back that bolt out and re do it.
Thinking back on it, I don't think there were any specific numbers in the install manual.
