05stroker
Never enough power guy!
This is off my car, its part number 30-3000. Kit also has the filter, duel nozzles and both the boost referenced and MAF referenced control units with it. Use the one you want and sell the other. Comes with 10' of tubing. Depending on your setup, you may need a little more. The tubing is the same what is used on sir line for big tucks, so it is easy to find if you need more. Fastenal also carries the tube and fittings. There is enough here to make it to the engine bay from the trunk. It made it to the blower on my kids DOB kit, but would be short for my Procharger set up for reference. Not that it matters, but the nozzles have been fileed down for clearance.
$300 shipped low 48
$300 shipped low 48
