I bought the DL1 on ebay...used....for $401. I was a little nervous, but it works fine. I got the OBD cable for it through SPS.
I can't say what will be available with the obd cable on the aim system. Just looking at track maps, speed gradients, and lap overlays along with lat and long acceleration numbers will keep you busy for HOURS. It's a lot to take in.
***It occurs to me that you may think we are talking about the same thing. I am running the Race technology DL1, not the AIM Solo.***
ahh that clears things up. I understand the boatload of time that can be spent compiling data and merging with videos or diagrams. AIM has their own data analysis software that can be used. I think it's merging the data with video that will take time.
Here's a list of channels that the AIM Solo DL can receive from a Mustang (any copperhead?) ecu.
Taken from this website:
http://www.jimmypribble.com/blog/2012/12/review-aim-solo-dl/
Appendix A – Data logged from Boss 302 ECU:
RPM
Speed
Pedal position sensor
Front left wheel speed
Front right wheel speed
Rear Left wheel speed
Rear right wheel speed
Traction control
Traction control alarm
Fuel level
Instantaneous fuel consumption (1)
Instantaneous fuel consumption (2)
Average fuel level
Fuel flow
Clutch switch
Traction Control Brake Event in progress
Engine Control Engine Event in progress
Brake switch
ABS Alarm
Axle ratio
Malfunction Indicator Light
Fail safe cooling mode
Gear
Tyre size
Stability Control Telltale NO/YES
Stability Control Telltale Text Message (code)
Electronic Stability Control event in progress
Torque
Brake Warning Telltale ON/OFF
Vehicle Yaw Rate
Vehicle lateral acceleration
Steering wheel angle
Tyre revolutions for mile
